No water on side cooling water pilot outlet
Paul Steele
Columbus OH
212XD
No water from the starboard side cooling water pilot outlet in my 18 242se
Got it to the ramp and moving over to dock waiting on family when noticed no water from pilot outlet
Engine has thrust in forward and reverse
Turned it off let it sit - pondered the issues - no clue what to do from here
Fired it up one more time and still nothing
Killed the engine and got it out of the water on one engine
I pulled the caps and nothing tangled up
Crawled underneath at home - nothing in the intakes at all
Any suggestions - under warranty - will get it to dealer
Scottie
Helena, Alabama
Have you checked the hoses at the fittings? Also, make sures the outlets aren't clogged. Dirt daubers, etc like those openings. Water flow from the cooling outlets is just a visual indicator for you. No water from the outlets does not necessarily mean there's a cooling problem in the engine. In fact, it usually does not mean that.
many times you won't get flow unless you increase the RPM's significantly,
I agree with the above, most times lack of flow isn't enough to make you go home but it should make you question, lack of flow and an overheat alarm would be enough for me to shut it down and come in,
run a weedeater line 3ft down the openings and go out to the lake and try it again at higher rpms to help diagnose it,
