NOCO 2x2 charger reduced at Amazon
Ok now it makes sense! Thanks for the response.
Since this is new to you, I’ll also add that the factory generator that charges the batteries via the motor is more to keep well charged batteries charged. Charging well used batteries back up requires a charger you plug in once returning to your place of storage. Since you have 3 batteries, you probably have a high consumption device, like a high amp sound system, and an onboard charger should’ve been part of that install. So when you aren’t using the boat be sure to plug that in. HTH
Will do thanks.
