Ronnie
- SF Bay Area
- Limited S
I've owned various personal watercraft (pwc) , mostly used, for over 25 years now so i have had to replace many of the oem batteries. Well as luck would have it the shop that is tuning up my son's new to him 1996 waveblaster called to tell me they were done working on it but that battery wouldn't take a charge. I decided to grab a battery at Walmart so that my son and I could possibly test the waveblaster out, weather permitting, when we pick it up later this morning. It wasn't until I was prepping the battery, per the mfgs instructions and as I had done many times before that I started wondering why I had to prep these batteries and not others and why the instructions are written as they are.
this is not a sealed battery like the Optimas, it's a conventional battery similar to the ones found in most of out cars but it is an AGM (absorbent glass mat) which I've read are more resistant to damage caused by vibration. It costs twice as much as its non agm counter-part, at least at wall mart. For those that haven't had to do this before, these smaller 12v batteries do not come ready to use, some assembly is required. This is important to know, especially if you have a dead battery and need to replace it right away in order to get on the water. Generally, to get the battery ready for use you have to add the included fluid to it and let it stand for 30 to 60 minutes before charging it for 4 to 10 hours at a rate of no more than 2 amps. As such if you need one of these batteries for immediate use you have to buy and prep it a head of time (in my case the night before) because of the initial charge interval.
Now that I've outlined the background I can move on to the observations and questions. I think that the reason I have to assemble/prep these batteries and not the ones I buy for my cars or boat because the smaller batteries tend to sit on store shelves longer and the mfgs don't want them to die / go bad prematurely. Also the acts of adding fluid and charging such batteries initially are the the triggers for starting their service lives.
Why don't we use these batteries in our boats? I had a yamaha boat and pwc that used the same engines but nit the same batteries. Maybe its because a boat's battery is hooked up to more than a pwc battery normally is (e.g. Stereo, depth finder, etc.) so a boat's battery needs to have a larger capacity. In dual battery situations like the systems found in the yamaha l and ls models using a smaller battery for the engines could reduce the weight considerably compared to a standard auto battery.
Is the battery acid just distilled water until it is added to the battery and the battery is charged initially? I've had to add fluid to car batteries before and have used, per instructions, distilled water as well as dedicated fluid from the auto parts store. The contents of the dedicated fluid as far as I recall are distilled water and electrolytes (similar to what's in Gatorade, maybe that is why it is yellow not clear).
If the acts of filling and charging a battery are what triggers it's useful life why don't the batteries in cars go through the same user prep? What I'm getting at is, if both types of batteries have 5 year expected service lives and both are manufactured on the same day, shouldn't the larger auto battery die one year earlier if the smaller battery is not filled and charged until a year after it was manufactured?
Why do the instructions require that the battery stand before charging it inially?
The instructions go on to state that charging at over 2 amps is not recommend and will reduce the life of the battery, yet my standard charger has a 2 amp and 6 amp setting and my onboard (boat) charger has a 5 amp setting, many charge at 10 amps. Shouldn't chargers be limited to 2 amps to prolong battery life? Or are the amp charging limits directly related to a batteries capacity? That is the bigger / larger the battery the more charging amps it can handle?
This may seem like a stupid thread to start on a boating forum since most of us don't have to deal with the smaller pwc batteries but I was just curious about everyone's thoughts on my observations and questions. Additionally, I'm trying to understand battery technology a little better now that my son and I are working on his pwc together as I'd like to give him better answers to his why type questions than just "... because the instructions say so." I'm also curious because the latest generation of radio controlled toys that we are getting or have gotten into use lithium polymer batteries that have been known sometimes to malfunction and explode/burn so I have to be more careful about how I maintain those batteries and again I would like to better understand why that is the case.
