kthrash
- Madison, MS
Got an OEM mount coming.. stay tuned for details.
Surprised it's not made of stainless. Looks nice either way
Factory mount was fine on my 190FSH with an 80lb thrust motor, the factory mount on my 210FSH with a 112lb thrust motor tore the front of my boat up.
I am using an 80lb, 24 volt 60 inch with batteries in the console and it does great. Get a plug so you can easily take it on and off so the mooring cover will fit. It is a great cover and you can take it on and off on the water.Greetings - I appreciate all of the good info, I've got a 210 FSH on order and have been trying to educate myself about several things most relevant being trolling motor choice and size, the other being the factory mooring cover so here goes:
I'll be keeping the boat docked in the water (Great Lakes - Erie), I'm wondering if the factory mooring cover is designed well enough to easily be used and taken on/off while in the water or would I be better off with a custom made version?
My trolling motor thoughts are to limit weight with a 24 volt 80 lb thrust 60 inch unit. Am I thinking correct here or am I making a mistake?
