- Naples Florida
- SX
Yum..... I need to move closer to you!
The Keg is always open if your in the area.Yum..... I need to move closer to you!
Normally I'll force carbonate for 2-3 days. first 2 days at 25-30psi then evaluate. If it needs more, usually just one more day at 20-25 is enough.Just tapped a keg of Hefeweizen last night I made 4 weeks ago. I've had the keg on co2 for just 5 days , so the beer needs more time to just sit and carbonate. Gonna be a good one for hot weather though.
no, I don't carb through the out post, I do it on the in post. no offense taken by your comment at all. Always learning new techniques. Makes perfect sense to carb through the out post. I might give that a go, but would mean some hose/ball valve connector changes I need to make to my kegging system. Not a huge issue though.Normally I'll force carbonate for 2-3 days. first 2 days at 25-30psi then evaluate. If it needs more, usually just one more day at 20-25 is enough.
Also, I cold crash at the end of the primary/secondary so when it hits the keg for carbonating, it's already cold which helps.
I never do that shake/roll BS. Just time and pressure. Make sure you're forcing through the serve port. (Don't mean to insult if you already know this, just pointing out my process)
Not sure what you have on your setup but mine are the standard ball locks and corny kegs. They are pretty clever with the fittings. The CO2 one will fit on either side but the serve fitting will only fit on the serve side. Crank that pressure up and cut your carb time way down. I get antsy...especially with a beer like the creamsicle ale that sits in secondary for 10-14 days....I want it to carb up quick! But I'm still not impatient enough to use the rock and slosh method...too much room for error there if you ask me.no, I don't carb through the out post, I do it on the in post. no offense taken by your comment at all. Always learning new techniques. Makes perfect sense to carb through the out post. I might give that a go, but would mean some hose/ball valve connector changes I need to make to my kegging system. Not a huge issue though.
My normal plan is to cold crash like you said. transfer to serving keg and put that new keg in my main beer fridge hooked up to CO2 at serving pressure (usually 10-15 psi). I will let that keg site 8-10 days and it will 99.9 % of the time be fully carb'ed and ready to go after that 8-10 day time. I just got antsy on this one and took a pull after 5 days.
Thanks...It really does come out awesome....3 pounds of orange blossom honey (which is a fermentable sugar) at flameout and then in the secondary I put the zest of 3 oranges and make an extract with 10 madascar vanilla beans and a very small amount of vodka. Sits in secondary for 10-14 days. Last time it came out to about 8%abv. The honey really kicks it up. I need to look at my notes, I think I added some bottling sugar in the primary too...have to be careful though, too much and it dries out the finish. It's sneaky...goes down easy but kicks you in the butt.@Big Shasta that creamsicle ale sounds awesome!
That's a cool idea for folks that don't have room at home to make big batches. Could be really cool for assistance when newbs like me go to all grain brewing....but I told myself I won't do it without a good conical fermenter setup like this. http://www.ssbrewtech.com/collections/fermenters/products/chronical-14-gal-fermenter-brewmaster-edition-1Just kicked my keg of the black IPA that I brewed over the winter. My plan was to have one ready for when it kicked, but then we decided to buy a new house and move, so all my brewing gear went into the storage unit 3 months ago! We move Aug 5th, so hoping to get one going once we settle there.
There's also a new homebrew store that opened recently that offers on-site brewing and storage for fermentation. They were also talking about setting up a lagering area, so may have to give that a shot.
