atldude
- Atlanta, GA
- SX
Hi fellow Jet Boaters!
So I am having a bit of an issue with what I believe is an oil seal on my 2006 SX230 HO.
Yesterday I took the bout out to the lake for the first time. Was a blast! However on the way back around 7000rpm ~30-ish mph the port side started making noise which sounded like vibration.
I let off the throttle, shut it down, looked in the port clean out and there was nothing that I could feel. I started the boat back up, no issues when idling. So I continued heading back running slowly. When I got close to the marina, I decided to test things out a bit. I realized that when I only use the port engine, the noise comes back right around 5-6k rpm but ONLY IF I only use the port engine (starboard idling). When I use throttle on both engines the noise is not present. Comparing how the boat runs on each individually, the power delivery less on the port side but not as if I am not moving or anything... just not as quick and pronounced as running only the starboard side.
So initially I thought maybe I hit some debris and it chewed through them but now I am having issues with cavitation. Was king of hoping for it anyway my small fear was that this has something to do with the intermediary bearing of course though I thought I'd probably hear a lot more across the RPM range if that was the case.
So today, I got the boat out out on the service stacks and took the port pump out shaft looks good, impeller looks good (not great as there are a few small chips on the leading edge but nothing I thought would cause major cavitation issues). Nothing in the removable pump assembly including bolts, bearings etc. make noise or are loose.
With the pump/shaft out I started the port side and bumped the throttle for a quick second (boat was completely cold and fresh out of the water) up to 5k rpm and I heard or felt no vibration at all.
Decided to take a look down the barrel of the shaft tube and here's what I saw (not easy to take a good photo down there) -
There appears to be a rubber seal/sleeve that's chewed up and completely free spinning across the tube (not just laterally). I can only assume is #8 or #5 on this parts diagram but I am not sure which one -
Looking for some advice as to how does one go about replacing these outer oil seal(s). I am not sure if the bearing is shot altogether. I can't tell just by looking down the tube but I'm speculating maybe the noise/vibration was caused by the tore up rubber seal being dislodged and freely moving around catching on the shaft and the tube walls when engine/shaft is at speed. Is it possible to replace the most outer seal #8, see how it goes and then go further to get to the intermediary bearing assembly?
Any thoughts/advice would be greatly appreciated!
Cheers!
Cheers!
