lukedukem
- Other
- Other
Hello all. New to the group and need some help. I have a older home made jet boat that is powered by an Oldsmobile 455 and Berkeley 12-JC jet drive. Here’s my issue.
Last Friday (8-18-23), I pulled the boat to my house to redo the bunks on the trailer. The boat hadn’t been ran for about a year. After completing the bunks I decided to run it in my yard to see if all was good. After checking the oil and water I fired it up. It ran for about 20-30 minutes and started to over heat. I noticed water in the bulge and thought water pump. So I shut it down. Picked up new water pump and replaced. Also drained the oil which looked fine and put on new filter. Went to fire it up and it had stumble and finally smoothed out. Not couple minutes in and it got hot fast. Shut it down and sat and stared at it. Checked oil to make sure I didn’t need to top off and it’s milky.
My first thought was head gaskets so I removed both heads and they don’t show any signs of blow out, not but 100hrs on these. Then I thought about the freeze last winter down here in Texas and that I didnt drain it. Check heads with flat bar and they don’t looked warped. Plus again gaskets look good. I’m stumped as to where the water got in the oil and why it got so hot so quick. I am running a closed loop water system with 4 pass exchanger cause I’m just using salt water to cool engine water. Plus my exhaust is the log type with water cooling in them as well. Here some pics. Any one have any place to start looking for issue.
