kthrash
- Madison, MS
@kthrash that works, but you are not fully utilizing all the power from your amps. For example right now you are getting about 75W per inboat speaker and 100W per Tower Speaker. If you swich the in boats and the tower speakers where they are connect on the amps, you would still maintain 75W per inboat, but the Towers would then be 200W per speaker. With it that hooked up that way, you probably use a lot less battery power though....
so use the M600 to drive the in-boat Speakers in parallel at 2ohms... and the sub in bridge mode, and then use the M400 in bridge mode for the two tower speakers?
