John McLaughlin
- Ocean Pines Md
- SX
I was out boating this afternoon when my starboard side engine was running fine but then stop producing any thrust. I was probably running at 5500 to 6000 RPMs. I shut the engine down and came home on one engine (One can say what they want about two engines but I will never have another single engine boat). I read the Engine Trouble thread started by Wilco. Because the engine has no problem starting I have eliminated the timing chain issue. Because it was rough and I was by myself I did not check to see if the access port had popped loose. I checked at the dock and it was not, however, I did not take it off to see if there was debris inside it. I did start the engine when on the lift. It started quickly and did not sound rough. Anyway is it possible that debris got stuck at the input and came loose when placed on the lift or should I be looking for something else?
Thanks for your assistance
