swatski
- North Caldwell, NJ
Exactly what @GiddYupJoe said, also open the reverse gate (push the throttle/s forward) to prevent water pressure building/backing up inside the pump(s).I'm a single engine boater so it's not applicable, but curious...
I understand when you are being towed, you have to either do some work to prevent water from coming in to the engine or be towed at very slow speed. Wouldn't the same apply when coming in with a single engine running only?
