If you guys can get that boat for 5-6k, assuming it runs and does not take in water, that could be a great project and a lovely boat and a lot of fun.
But, keep in mind that it is not just the electric, gauges and mechanical issues. If the wood panels (encapsulated in fiberglass) such as in transom, stringers, and deck are rotten... that could be a very BIG project to make it seaworthy. Looking for any soft spots can be tricky, too -- I would try to get yourself familiar with WHAT TO LOOK FOR, thehulltruth has thousands of projects you can check out. Than go look at the boat and decide.
I cant remember if it was said in this thread but look at the top of the jet pump pic its missing bolts and seals where the cables come out this means its likely taking on water while out so check that out.
I think much of it has to do with your (and his) objective in having a boat.
If you (he) wants a project boat that he can learn to take apart in his sleep and will have fun fixing gauges and hunting leaks and finding gaskets and maybe take out a couple of times a year (because the rest of the time it is in pieces), this may be the boat for you. As others have mentioned, $9k would be steep for such a project boat.
If you (he) wants something that the family can take out every weekend (or nearly) and go cruising in, that will not be this boat. Even if you don't do it yourself, it will be in the shop all the time. Or if you want something to tow folks. Or host another couple and cruise. Or have the kid and all his friends out on. Yeah, all of those things, then I would say you need to look elsewhere. But looking elsewhere for a boat that will be reliable and much more flexible to these goals will probably run you more than $9k.
If you have $9000 to spend find yourself a nice Yamaha LS or LX2000 2000-2002 vintage. Great inexpensive family boat and if you look for some one on here selling one you will get one that's likely in great shape. You'd probably pay $6000-9,000 and have a great starter boat that's fun for the family and inexpensive to maintain.
I run mainly the Susquehanna River here in the Harrisburg area, the deepest depth I've seen is 10'. After two summers of boating this river on my own and 3+ years beforehand on OPB (other people's boats) I feel confident in running right up to the 1.5' depth. Our waterbed ranges from rocky to muck to sand (odd I know).
I have a 2008 SX230... Just to give you an idea of what I'm working with. Obviously I'm not going to try and get on plane at 1.5' but as soon as the depth is over 2 feet I typically will.
Good luck with your search. I'm curious to know what you decide. I personally would go with a more modern jet.
Do a compression check for sure. I just bought a boat that ran fine for the test drive, and my first day. Then it had problems starting. The compression is bad I should have run the test. I said I would, but the engines liked great, and ran prefect. Oil looks fine too.
