Nakk
- Camas, WA
I got this pipe insulation from Amazon, fits the table leg for my 2017 AR240 perfectly. I cut two pieces, one for the lower section and one for the section above the bend. The lower section needs to be slit--it's partially pre-slit--but the upper section slides right on and doesn't slide off unless you pull it off. It helps prevent damage both to the leg and to other things it might hit if it bounces around while underway. Amazon.com: 2-1/8" x 6 ft. Polyethylene Pipe Insulation, 3/8" Wall: Home Improvement BTW, the picture on Amazon shows the insulation pre-slit with adhesive pre-installed. That is not how mine came. It only is pre-slit about 1/8" through the 3/8" thick wall. No adhesive.
