14SX190
- South Florida
- SX
Well here it is.
I took remachined head and bottom end to local JS shop. Had him install new OEM gaskets, chain and set TC and torque everything for $200 bucks.
I think it was fair seeing what I saved doing everything else myself and din't want to fudge that up.
Got rest of engine dressed with new block anode #10/#11, rebuilt dipstick with #36/#37/#40, o rings for #25, gasket for #18 for cooling passage covers. New oil cooler o rings to block, SS clamps for hoses running from oil cooler, finished with re wrapping wires with electrical tape.
Now for my question to help me bolt it in the boat
tomorrow to fire it up.
JS shop did not torque bolt holding oil gear. He said to use piece of wood to keep PTO from spinning as I try to torque it at 80 N.m or 59 ft-lb.
I tried but engine rocks on pan. I can't get leverage by myself.
May take it back tomorrow and have him do it if I cant figure it out or get friend to help hold wood and engine down. Any ideas?
Also, it asks for 1280B sealant on the front half circle of intake. Is there an alternative sealant to go there? Is it any RTV Silicone Liquid Gasket?
The SM also does not show diagram to a tightening pattern for the bolts. It just says criss cross 8 N.m or 5.9 ft-lb? So Start with middle top bolt then?
Hoping to test Friday rain or shine
