swatski
- North Caldwell, NJ
[EDIT: If you use your boat to just cruise around, your twin Yamaha is perfect (leave it alone)!
But, if you plan on doing activities that involve pulling heavy loads at very low speeds, such as wake surfing, you WILL experience cavitation due to the fact that pump loading is less efficient (with boat NOT moving on plane). If that is the case, you may consider
an approach of tuning your anti-cavitation mods one engine at the time
to simply improve your testing efficiency, no need to prep the load etc. every time you test a new component. ]
The twin Yamaha jet boats, such as my AR240, afford sufficient thrust for excellent acceleration, stock. It would be hard to complain about the factory setup. Still, there are practical considerations to try to better it. For example, when running with a heavy load (say, 12 people), or hauling lots of wake surfing ballast -- one can hit a limit of a boat's planning capacity rather quickly w/factory (stock) setup. Or other scenarios, like running heavy-loaded in rough water, climbing waves in 5-6+ft seas, where big thrust can be vital.
In this context, I'm having a hard time wrapping my head around the issue of what would be the best approach to tuning anti-cavitation mods in a twin.
With the single engine/pump, it is pretty simple. You either have slippage or you don't. For example, hit the throttle hard (as in all the way to WOT, fast) and you will see what happens. In the case of my 190, I had a lot of cavitation/impeller slippage especially after I reflashed the ECU for more torque. It would present as a "wha-wha-wha-wha" sounding process of impeller slipping and engine bouncing off the electronic rev limiter for few seconds (the first 3-4 sec of the run in the video clip below, where there is a lot of slippage); after that the boat would pick up enough speed to help load the pump, the impeller slippage would stop, and the boat would pull off with no more impeller slipping:
Kind of the same issue as loosing wheel(s) traction in a car. I hated that, when my impeller was slipping, and experimented with various "solutions" before I settled on one that worked best -- it was the Lucky 13 anti-cavitation cone. It was a bit of work to dial it in but after that the boat would pull a lot stronger (and sound better):
If you compare those two clips (the first few seconds of each) I think it is quite evident the cavitation at the start of the former. Which is (mostly) eliminated in the latter. With no slippage comes much stronger pull out of the hole, ability to haul a big load, etc.
With the twins, I am a bit lost. The reason being that I don't hear or feel a lot of impeller slippage running with the two engines. But, is there really no cavitation? Or is it just masked by the excess thrust from two pumps?
I think it is the latter. The simplest test is running with one engine. I played with that a bit last weekend, and the results are obvious: there is TONS of cavitation when running on one engine, LOL. It is actually worse than in the single engine boat, but it is the same process I think. I don't have a video clip, not needed -- it is very obvious, running with one engine at high idle (to prevent flooding it) and pushing the other one hard creates conditions with just awful/excessive amount of impeller slippage. We all know it.
So, to me this presents an obvious question: should the cavitation issue be approached (and resolved) at the single engine level? And, if successfully tackled, would the boat gain epic amount of thrust running with two (individually tuned) engines?
Am I missing something?
And just to be clear - this is NOT about the impeller pitch angles and rev limits. I understand the correlation between the impeller pitch, revs, top speed. Of course I can eliminate impeller slippage by increasing the pitch (trailing edge), but that will decrease the top speed, etc, etc, an entirely different discussion. What I do not know, and wonder about, is if anyone tried to dial in their pumps individually in a twin boat, and what was the lesson/experience. Is there a benefit in tuning the pumps individually for maximum efficiency?
