Picked up used Scarab 255
WaveJunkie
Scarab
I've had a NauticStar 230 with a Yamaha 250 for a long time. The kids are old enough now to ski and wake board. Went to a boat show. Looking at the electric boats for $300k 😵 with no hope and a sales guy talks the wife into a 2016 Platinum 255 HO very clean and has 100 fresh water hours. I'll have the boat in a couple of weeks. The dealer is installing a Scarab tower.
Is ok to run the boat using just one motor?
blthlt
Charlotte NC
Scarab
255 ID
Short answer, yes you can. Long answer don't do it unless the 2nd engine won't run. Requires hoses to be pinched to avoid hydrolocking engine.
WaveJunkie
Scarab
Excellent thank you. I need to get a manual.
Just want to ask, is there anything I should do or check at 100 hours?
WaveJunkie
Scarab
Thank you for the link to the manual and the tow clamps.
Did a little searching. Sorry if this stuff has been discussed before.
Does everybody use those oem clamps?
And is there some kind of "tool" to have just in case something gets lodged in the water intake grates? A coat hanger ?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
Scarab
165 G
You can use any large hose clamp including the OEM one. But it's easier to get a generic one somewhere.
As for tools like that, I recommend carrying a pair of super long needle nose pliers like this. Mine are 16" long.
Some also make something like this:
Some people seem to need these way more than others. lol A combination of the waters you're one and how you drive. In my case, needing any of this is extremely rare. Now at over 260h and only had one such incident and it was because I was running in 12" of water and fully knew what I was doing. Sucked up a stick but I was able to get it out. Had to swim under the boat with a mask and waterproof flashlight.
WaveJunkie
Scarab
Great thanks for the insight. I definitely will get the long nose and get a waterproof flashlight-
I’m looking forward to great times with this 255 when I get it in the water.
