swatski
- North Caldwell, NJ
I may need to do some testing, and observe which configuration is more prone to clipping.Be careful with the Polks. I am not recalling if it is the db series or the mm series or both but the true impedance on them is 3.7 ohms which when split in two gets dodgy for the amp. @Bruce made a good comparison to pushing things uphill. Impedance is resistance and I like to compare it to deadlifting. If you think you have 400 lbs on the bar but only have 200 lbs then exert 400 lbs worth of power that bar is going to come up with much more energy (watts in this comparison). Doing this multiple times as a human means you can do it quicker and your heart rate goes up quicker so you heat up. If an amp is not 2 amp and stable or there is too much load on a 2 ohm stable amp it will overheat or clip the signal.
