Speedling
- Cedar Lake, IN
- SS
Also, if it shakes bad, pull the pump and shaft out and run it again. If it eliminated the shakes, then it is a pump problem.
I had a heck of a time aligning the pump up perfectly when i put it all back together again. It just wouldn't go in perfect. The old pumps have shims and a top bracket that the newer style doesn't have. That caused and eliminated some shakes once it was dialed in.
