Good call, I’d be demanding a refund on that serviceDealer prep $1K, that would have been found if they did their job, they did not go over the boat, its their job to inspect everything before handing over to customer. Boat with a hole, OK to sell - CHECK!
Do the repair yourself or slap 4200 Fast Cure on it and deal with it later, or Water Weld. I carry both in my tool kit in my boat just in case as well as a 10" x 10" of Flex Seal in case I hit something or in an emergency.Also what do you do when you boat has a hole in it and you can't go to the lake? Sit in the driveway and drink a few beers with the family.
This was a sarcastic post to a bad situation. I could fix this myself yes, but this will be fixed by Yamaha and documented or I won't have a boat. I'm very aware that if I return it, it would be fixed and sold to the next person on the wait list the next day. But this is a manufacturer defect on a boat that has never seen water on my behalf or even been turned over. It has .1 hours on it.Do the repair yourself or slap 4200 Fast Cure on it and deal with it later, or Water Weld. I carry both in my tool kit in my boat just in case as well as a 10" x 10" of Flex Seal in case I hit something or in an emergency.
Some people have hit coral or clam beds and tore off a good part of their underside and just patched and kept on till they could fix it themselves or take it to a shop.
Have them fix the boat and ask for a free extended warranty. My brand new boat was delivered with a bad engine that blew the top end the first day on the boat ramp. Ask for some compensation. Start with extended warranty, 10 hour service for free, and a free cover and see what they come back with. I got everything I asked for. Good luck!This was a sarcastic post to a bad situation. I could fix this myself yes, but this will be fixed by Yamaha and documented or I won't have a boat. I'm very aware that if I return it, it would be fixed and sold to the next person on the wait list the next day. But this is a manufacturer defect on a boat that has never seen water on my behalf or even been turned over. It has .1 hours on it.
Sounds like the dealer has offered more to you than any other dealer spoken of here given the current retail climate, and appears you are already on the right track to have it fixed properly. Patience usually pays off.So update. Dealer has offered to tear up my check if I want to go that route. I've been assured by multiple people that this will be repaired in less than 3 days if I want to keep the boat. It will be guaranteed. It is going in as a non sold boat repair. (Manufacturer defect). They are sending someone up to pick up the boat and return it to me. They say it's an easy fix only in the gel coat and not the hull. This repair will be documented and have a paper trail incase any issues from it come up in the future. (My thoughts) First off I'm frustrated. Spent $40k plus on brand new boat and this happens. I was literally downstairs getting my cobra steering and guide poles to put on when dad found this. 2nd if I return this I won't have a boat till next summer, I've already been waiting 6 months. What are your guys thoughts? Thanks in advance
Well if you can see through it the hole is through the fiberglass as well. The gelcoat is only a non structural coating. The fiberglass is the structure. This will need to be ground out from both sides. Laminated with fiberglass, then apply gelcoat. otherwise it is a band aid repair. I would ask to have the repair approved by a Marine Surveyor. There should be some compensation of some sort. I was in the Marine Repair Business and a boatbuilder for over 1/2 of my working life.So update. Dealer has offered to tear up my check if I want to go that route. I've been assured by multiple people that this will be repaired in less than 3 days if I want to keep the boat. It will be guaranteed. It is going in as a non sold boat repair. (Manufacturer defect). They are sending someone up to pick up the boat and return it to me. They say it's an easy fix only in the gel coat and not the hull. This repair will be documented and have a paper trail incase any issues from it come up in the future. (My thoughts) First off I'm frustrated. Spent $40k plus on brand new boat and this happens. I was literally downstairs getting my cobra steering and guide poles to put on when dad found this. 2nd if I return this I won't have a boat till next summer, I've already been waiting 6 months. What are your guys thoughts? Thanks in advance
Repair the boat. Get a discount for your troubles. Talk to the dealer owner, not salesman.So update. Dealer has offered to tear up my check if I want to go that route. I've been assured by multiple people that this will be repaired in less than 3 days if I want to keep the boat. It will be guaranteed. It is going in as a non sold boat repair. (Manufacturer defect). They are sending someone up to pick up the boat and return it to me. They say it's an easy fix only in the gel coat and not the hull. This repair will be documented and have a paper trail incase any issues from it come up in the future. (My thoughts) First off I'm frustrated. Spent $40k plus on brand new boat and this happens. I was literally downstairs getting my cobra steering and guide poles to put on when dad found this. 2nd if I return this I won't have a boat till next summer, I've already been waiting 6 months. What are your guys thoughts? Thanks in advance
If it is getting fixed, do not contaminate the area with any sealant, It will be a bigger job to remove all of it to get a good bond with the FRP and gelcoat. Yamaha should be offering all kinds of freebees to you on this one, I can't believe their lack of QC, getting this low as to let a boat leave the factory with a hole in the bottom.Do the repair yourself or slap 4200 Fast Cure on it and deal with it later, or Water Weld. I carry both in my tool kit in my boat just in case as well as a 10" x 10" of Flex Seal in case I hit something or in an emergency.
I was told by my fiberglass repair shop (also builds Recon fishing boats by hand) that if you can't get fiberglass properly repaired, just seal with packing tape. That way the repair shop doesn't have to grind out all the resin.If it is getting fixed, do not contaminate the area with any sealant, It will be a bigger job to remove all of it to get a good bond with the FRP and gelcoat. Yamaha should be offering all kinds of freebees to you on this one, I can't believe their lack of QC, getting this low as to let a boat leave the factory with a hole in the bottom.
Check the anchor locker drain. Make sure the plastic fitting goes thru both layers and it is sealed. Many are not sealed and the fitting is too short and owners hunt for the source of water in the bilge.
Edit: West Systems epoxy will seal the hole and raw FRP, as a temporary fix, without causing contamination issues.
There is no way that is "only in the gel coat"! You can see foam coming out of it if I'm seeing the picture right. You can even see fiberglass layers in the hole can't you? That is a through hole or at least into the fiberglass. A good shop could easily fix this good as new if done right but the fact that the dealership is already lying to you about what the repair entails makes my insides churn. Given them telling you that this is a gel coat only fix I'd be very skeptical and would get more information exactly how this will be fixed. I'd want to have direct communication with the shop that is doing the repair to make sure it is done right. Unfortunately you have very little leverage in the current climate of boat sales, you have to do what they say or rip up the check and they will easily have another buyer in queue after they fix it. Good luck but stay vigilant on this to make sure it gets done right!So update. Dealer has offered to tear up my check if I want to go that route. I've been assured by multiple people that this will be repaired in less than 3 days if I want to keep the boat. It will be guaranteed. It is going in as a non sold boat repair. (Manufacturer defect). They are sending someone up to pick up the boat and return it to me. They say it's an easy fix only in the gel coat and not the hull. This repair will be documented and have a paper trail incase any issues from it come up in the future. (My thoughts) First off I'm frustrated. Spent $40k plus on brand new boat and this happens. I was literally downstairs getting my cobra steering and guide poles to put on when dad found this. 2nd if I return this I won't have a boat till next summer, I've already been waiting 6 months. What are your guys thoughts? Thanks in advance
I would agree with this - in fact if that were my boat, I would be inclined to take it back to the dealership then, with the dealer watching, stick a long pin up through the "gelcoat" hole and see how far it goes. I'm guessing that you could punch all the way through to the inside once you're past the foam.There is no way that is "only in the gel coat"! You can see foam coming out of it if I'm seeing the picture right. You can even see fiberglass layers in the hole can't you? That is a through hole or at least into the fiberglass. A good shop could easily fix this good as new if done right but the fact that the dealership is already lying to you about what the repair entails makes my insides churn. Given them telling you that this is a gel coat only fix I'd be very skeptical and would get more information exactly how this will be fixed. I'd want to have direct communication with the shop that is doing the repair to make sure it is done right. Unfortunately you have very little leverage in the current climate of boat sales, you have to do what they say or rip up the check and they will easily have another buyer in queue after they fix it. Good luck but stay vigilant on this to make sure it gets done right!
