LukePrinsloo
- Fort Mill, SC
So I got started replacing my intermediate bearing this weekend with a @ISLANDRACING bearing assembly. Turns out my 2011 AR240 Has a thrust washer behind the assembly that I needed to order.
So I decided to tackle the myriad of scratches on my boat. The prior owner insisted that he did not need thrust vectors and proved it by hitting everything with the boat. I pulled the stock decals off and proceeded to find out that for most of the marks I needed to sand them with 600 grit. Then I used 1500 on a Dual Action over the majority of the area then Meguirs 105 on it all then Meguirs 205 to end. Multiple coats of each of the meguirs. The side next to the garage is actually done. The other side just got too damn hot to work on. A few of the scratches are still visible a little but substantially less than before.
The eagle eyed will see the different colored tapes. I used these as guides for my section passes with the DA.
I failed to get too many pictures of it inbetween stages but at one point my wife came out and I could tell she was very very worried I could not finish it out
I do need a good suggestion on a sealer/wax that will hold up to the water.
