CaptRedbeard
- Omaha, NE
Purchased boat this spring. Changed oil and filters in April. Old oil was not milky. We’ve put probably 20ish hours on it this summer - it has been running great. We’re just wrapping up a week on the lake and I noticed the port engine was only getting up to 7300-7500 at WOT. Starboard engine will rev to 8800-8900 (which might be a separate issue).
I checked oil and starboard engine is fine but port engine is milky but at the proper level. I pulled spark plugs and they’re a bit black, with the cylinder 3 plug being the blackest and having a moist substance on the threads/plug tip.
Is the boat okay to cruise around the lake in its current situation?
Looking for recommendations on order of things to check. I’ll be checking compression as soon as I get home to my garage this weekend.
