Port engine warning
robert843
Myrtle Beach, SC
[USERGROUP=9]@HELP[/USERGROUP] i just pulled off the trailer boat immediately through port engine warningBut everything seems to be fine RPMs are good water is flowing through both ports there’s nothing stuck in the grate engine has oil and Boat seems to be running fine any ideas what this could be should I turn around or am I probably good to go if everything seems OK
Only issue I can find is no wake mode isn’t working on port engine
What is the warning?
How high will the port engine rev? Is it in limp mode?
What is the oil level?
What is your battery voltage? I believe that low batteries have caused similar warnings.
Oil level looks good engine seems to be running fine it will go to the top of the RPM level the only thing I’ve noticed is In no wake mode the RPMs won’t go up and it will only go up with the throttle. Normal operation seems fine voltage said 14.2 when running. The 2017 ar240 don’t have a temperature gauge so I can’t tell what the temperatures are running on the engines but By touch of hand they both feel about the same. I ran in about an hour and everything seems fine the alarm is still going off hopefully it takes me back home fine I will drop it off at the shop on Tuesday
@robert843, you might consider buying one of the tools to read the error codes before what will likely be a big bill to diagnose.
I thought about it but the boats still under warranty and I have another small warranty issue I had been delaying getting done so I may as well drop it and hope it’s covered under warranty. I’m heading down to Miami this coming weekend to pick up my other boat anyways as well so it will be fine if it gets stuck at the shop for a bit.
first world problems LOL
Find those fishing spots off MB I'm ready!
Safe trip down and back this coming weekend
