2kwik4u
- Buffalo, NY
All good points and yes I agree. Truck EVs towing our toys are still aways away. Whats wild is that a 50kwh battery pack, the same size in a short range Model 3 has the energy equivalent to 1.5 gallons of gasoline. Thats it. EV's work well bc of the 3-6x efficiency the equivalent ICE gets but like you said towing reels that back in.
I was doing similar research this morning. How much energy is really in a battery pack vs a fuel tank. With 1 gal of gasoline equal to 33.7kwh. I would need a battery pack of 1,011kwh to make my 300 mile vacation drive with the boat in tow (assuming the truck get's 10mpg, and energy usage would be the same. If we use 3.4x efficiency over an ICE engine, we're down to 297kwh. I suspect towing is probably closer to 2-3x efficiency though due to significantly worse aerodynamics, and the higher loads.
Looking at out and out efficiency towing....The article I linked to above The Model X used (on average) 632wh/mi. This equates to about 53mpg. That is absolutely phenomenal efficiency in terms of straight energy usage. For reference, a pickup getting 12mpg equates to ~2,808wh/mi. This shows just how efficient the electric vehicles are (roughly 3.4x in this example), as well as how small the "tanks" are on the current EV's. Can you imagine buying a pickup with a 2.3gal tank to tow with? The guy in the link above managed 94mi average between "fillups" while towing. That's 7.8gal of fuel in a 12mpg truck.
These are very interesting numbers to me. First time I've really looked at the math of "is it really possible" scenario. If I was closer to the water in any direction it would be possible very quickly. If I had my own place on the water, or near the water, then I think I could make some habit changes to get me there. At the very least my own place near the water drops my requirement of range by 40-45% or so (Don't have to get all the way home, just back to the lake house from the ramp for a charge).
Rivian doesn't appear to have any spec's on it's batteries on the site (at least not that I can find easily). I'm curious what kind of usable range it has with, say, a 75% of full capacity load on it. For me, it still boils down to that power density issue, or faster recharge tech. Either would be fine really. The infrastructure will come in time, and the acceptance as well. My fuel stops on road trips is usually in the 20min range by the time I clean the windshield, fill with fuel, check cargo, take the family in to use the restroom, buy some snacks, and then get re-situated in the car. They find a way to put 500kwh into my truck in 30 minutes and I would call that a win.
@swatski you just took a long trip in a large SUV with a modern engine, a family inside, and a 24ft boat in tow. Any idea what kind of MPG's you were pulling down during that trip. Not intending to criticize, just looking for some data
