Bill D
- Prairieville, LA
- Limited S
This is really cool stuff. I'm excited to see how this turns out!
According to industry testing coated pumps are around 7% more efficient they also last longer in harsh environments. Perhaps a couple of MPH on top of what a what the boat would otherwise do in optimal condition.What's the measurable benefit? I'd want at least 5mph to make it with my time. Seems like a lot of work for a possibility immeasurable gain.
This article discusses a 6% increase in efficiency and 12.5% decrease in energy usage for a new water utility pump https://esemag.com/water/polymer-coatings-can-significantly-improve-water-pump-efficiency/ .Hmm. Are you saying 7% better mpg? Under all conditions? That would be huge.
I'm not sure that correlates well due to scaling issues. Their pump runs over 4400 gallon/minute.This article discusses a 6% increase in efficiency and 12.5% decrease in energy usage for a new water utility pump https://esemag.com/water/polymer-coatings-can-significantly-improve-water-pump-efficiency/ .
I have read other articles that talked about larger increases in efficiency in used pumps.
Of course our pumps are used differently so until someone (possibly me) tries it we will not know what can be accomplished.
@swatski, do you have thoughts on this?
That is exactly what I have learned! It is impossible to make predictions with our pumps, it is all empirical. IMO.Of course our pumps are used differently so until someone (possibly me) tries it we will not know what can be accomplished.
@Bruce Are you referring to something that would be a direct replacement for the Belzona product??@Chip F., I am having difficulty finding Belzona 1341. Do you know if your supplier sells it? My thinking is that I might use 2/3rds of the $350 500 gram package on one coat of the pumps.
Perhaps @Jim Robeson will find that one of the 3M Scothkote products would be perfect for us.
Yes, I am unsure if any of 3Ms products are marketed to compete with Belzona 1341 but it seems likely that 3M would produce a similar polymeric coating.@Bruce Are you referring to something that would be a direct replacement for the Belzona product??
I'll do a little research on Belzona and see if we have something comparable and let you know.Yes, I am unsure if any of 3Ms products are marketed to compete with Belzona 1341 but it seems likely that 3M would produce a similar polymeric coating.
@Bruce ... haven't forgot about you, just been busy. We are taking on some new products and have had my hands full lately. I did look at the MSDS on that Belzona and we have some, if not all of those raw materials in the plant. Just need to locate the engineer that has responsibility for those materials. Then I should be able to tell you if we have something like it or better.@Chip F., I am having difficulty finding Belzona 1341. Do you know if your supplier sells it? My thinking is that I might use 2/3rds of the $350 500 gram package on one coat of the pumps.
