Juan Negron
- puerto rico
- SX
Clean out are in Thanks!n Nice Boat looks like mine!
Can you post pictures of your impellers?Clean out are in Thanks!n Nice Boat looks like mine!
The factory impeller housing is made of aluminum with a stainless wear ring built into it. Some aftermarket housings use plastic wear rings.Bruce the impeller housing which I replaced thinking it was bad with a stainless steel unit, do I need a wear ring on this? I have the shaft and mid shaft out everything is tight I'm really confuse about this whole system!
