swatski
- North Caldwell, NJ
Regarding the RPM differences from side to side, the port spins faster in the new twins as Yamaha now installs two identical impellers on both sides. They used to pitch the port side a bit more aggressive (it was marked with notches on that neck). Changing the pitch is easy on the trailing edge (and it could cure the issue), any adjustments on the leading edge would be above my grade and may require bending tools, not just a crescent.So I still haven't gotten a set of replacement grates so I didn't want to do anything crazy yet. I decided to "blueprint" what was there. I cut the crossbar out of the stock grates and knife edged the bars. I also cleaned up the intakes a bunch, there was a pretty good ledge that the water would have to go over on the bottom edge of the intakes right in front of the impellers. This picture shows the beginning of the "porting" work I did. After I smoothed out the ledge, I filled and smoothed the rest of the gaps and holes in the intakes.
The difference was absolutely noticeable! I did everything possible to try to get either engine to cavitate, they didn't. I could go full speed and crank the wheel into a hard 360 (just put the cobra jet fins on it) and come out of it without touching the throttles. A little slip, but no cavitation whatsoever. Top speed looked to be about the same, but the pumps definitely worked better at all speeds and rpm's. I have no idea if it was the minor grate mod, the minor intake tunnel smoothing or eliminating that ledge on the bottom side of the impeller opening that made it so different. Sometimes it's simply doing a whole bunch of "little" things that make something work more efficiently. In everything I do on cars, that's always been true. Attention to details makes the total package work better.
Anyway, I may still put a couple of wings or blades on those grates similar to the loader grates later. I'm just not sure I can improve on the way it's working right now. What I'm going to work on now is getting both the engines synced up a little closer power wise. I'm thinking about either making a nozzle insert for the port side or boring out the starboard side nozzle a little bit. Same as it was stock, the port engine still turns a little faster than the starboard side. I either need to put a little more load on the one, or free up the load on the other one to even them out a little more.
Another idea, not mutually exclusive with boring the venturi nozzles - would be to use the Lucky 13 cones, where one can vary the number of spacers/cone volume - and totally tune in the RPMs.
I am following your progress, keep us posted!!!
