Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
So for service when you would only want to run one motor at a time on a hose; I’m assuming you just leave that key in off position to the particular engine not needed...
I did something a little different with the keys. Mounted them behind the helm on my accessories/power board.
For the push button start mod to fit in the ignition switch I bought 4 stainless washers 5/8 ID 1 1/4 OD. One on each side and snugged them down by hand.
This is definitely doable fairly easily with double start buttons (I'd suggest even in this case though you still only use one Stop button). In this case though you don't need the Push Button Start Kit as there is no need for programmable relays.
Basically you just use a single key switch to close the "ON" circuit of both ignition switches, use two push buttons to close the "Start" circuit on each ignition switch, and use one push button to activate two relays that close the "Off" circuit on each ignition switch. Not sure if you would need relays for the "Start" circuits as well, depends on the draw on those circuits and the rating of your push buttons.
Two start buttons with one stop button is certainly and one key is certainly doable. Relays are not required for the start buttons in that case but the putyins will need to held in until started instead of a quick press. Stop button will require isloation of the two stop leads.
Lots of ways to do this. Could even have just one button for it all with a logic controller for different lengths of press to execute different actions.
I thought a bit about the process flow and iser interface before landing where I did. Does not make my or anyone’s else flavor choice right or wrong. Just a personal preference thing kind of like where to mount the buttons.
I am thrilled with mine just the way @Mainah designed it ! Have had it for a couple months now and love it. Thanks again Chris for all the support during the install process.
