JDRacing
- Northern Calfornia
- 212X
Does anyone know whether the ballast tank seacock on "X" models, which has inlets for both ballast tanks, allows water to pass from one hose to the other? In other words, if you close the seacock are the two tanks/hoses connected via the seacock inlets? Or does each tank tube drain to an isolated part of the seacock and out the through-hull so they are not inter-connected? I'm thinking they would be isolated if they are supposed to be able to be drained independently. Otherwise pumping out one tank would send water to the other while trying to send it to the drain below the waterline. But not sure.
I ask because I'm trying to design a system to flush the ballast tanks without having to remove each tube/hose clamp from the seacock to hook it up to the lake authority's flushing line. Thinking of using diverter valve(s) in the hoses. If they are connected together via the seacock, I could use one diverter valve (installed in-line to one of the fill/drain hoses) to flush both tanks simply by closing the seacock (which sits on a bunk and is the reason I have to do this in the first place) and redirecting the water via the diverter valve toward the other tank through the seacock inlets.
Thanks for any insight.
Jeff
Jeff
