Sroc
- Michigan
- 252SD
Good evening jet boat hive. Quick question I just recently had my boat repaired at the dealership. If you recall from a previous post, I ingested a large piece of plastic it that the impala short story the dealer did a great job turning the boat around in a little over a week and a half I noticed on a post-run inspection when I went to open the drain plug of course I got a ton of water out, but I also noticed it look like one of these linkages is broken this was the same port motor that the impala was replaced is this something that the mechanic did? Please see the images. I assume it is a steering linkage though I do have the 252 SD. Again I am only asking because I assume they would have taken that linkage off to replace the impeller. I do not I did not hit anything today in the water today first day on the water since I got the boat back from the dealership the two images of said linkage port jet pump which has an impeller replaced at dealership past week and the one point if my starboard linkage for comparison
