Weeb
- Denver NC 28037
I did a couple winter upgrades, I put in two USB charging ports with the the volt meters that some of you folks have done thanks for the tip. I also installed six Accon Marine 1" fender quick release mounts. The ring portion snaps right in and you just pull the little tab to the left to release it. They are all SS. They charge $17 dollars for shipping so get everything you want the first time. I bought 4 then decided to get two extra rings for extra larger fenders when I tie up w my daughter, then I decided to put six mounts on the boat so I ended up getting two more sets needless to say financially it wasn't a good representation of my heritage. The mount sets are $35 a piece the rings alone are $13. I used 1/4" cutting board pieces for backing plates for the front and rear ones w 5200 in case I ever have to take one off it will stay in place. The middle one is about 12" behind the middle cleat so I couldn't access the inside of the hull. The front ones are a tad forward a bit because I went behind the speakers to get the backing plates on. The rear ones I went through the deck seat back storage area to get to the inside hull. They are very nice and will deploy your fenders fast and easy. I don't recall anyone mentioning these so I figured I'd throw it out there in case somebody is interested.
