- Florida
- Other
- Other
I have noticed that when running on the hose the stream is warm very quickly so it must be coming from the engine , if you do not have water coming out it does NOT mean that water is not present in the engine as the hose could be blocked . if the thermostat is not working you could have water and an overheat issue or if the water passages are filled with sand but that would be a consistent situation, you can also remove the thermostat and place it in a pan of water use a cooking thermometer to read the water temp while you heat it on the stove and watch what temp it opens at as well as the fact that it opens.
