NewBoater
- Virginia Beach
- 242X E-Series
A couple of weekends ago I took my wife daughter and a friend out tubing the engines overheated twice in a two hour span and I turned the engines off and a couple minutes later turned them back on no problems at all. Fast forward to the next weekend we went out with two more kids tubing and the engines probably overheated about five times in an entire day. Always started back up couple min later and always worked good. Put the boat on the trailer took it off the lift took it to the dealer they said there are no overheat alarms in the past 100 hours that are registered on the computer. They called Yamaha Yamaha suggestion was to run the boat with no water and see if the engine overheat would come on (which it did ). And then see if it registered in the computer system which it did. I am not blind or crazy it was definitely engine overheats as it said clear on the screen. Happened 5 to 10 times in the past three weeks and none of them registered on the computer system and the one that they got to overheat by running the engines without water did register. What could be causing this intermittent issue as I do not want to have to keep dealing with this if it keeps happening. And why is the computer not reading all of these overheats?
This is becoming a pain in the butt on the water to deal with the boat is a 2015 SX210 with approximately 125 hours. Getting ready to head to Lake Gaston for a week and don’t want to deal with over heats every hour.
On a sidenote I hope it did no damage to run the boat with no water until it overheated and then they said it turned it off as soon as alarm went off.
