Did you pick up one of their orbital buffers?When applying the Griot's One Step, I use a Griot's Garage Medium Correction Pad; it is Orange.
Orange Foam Correcting Pads
Get flawless car finishes with our Foam Correcting Pads. Remove light to moderate defects with ease. Ideal for auto paint, glass, and interiors. 3" -6" sizes.www.griotsgarage.com
If you are just applying wax (no polish/no correction), you would use a Red waxing pad (very soft).
If you are applying the Griot's 3 in 1 Ceramic Wax, you simply mist it on using the spray bottle.
When I got my new boat February, I washed it thoroughly and applied rejex only on the external hull so far its holding good, I only wash and wipe after each use and shine still there. Interior leather (seats) I applied 303 for sun protection. I do not know if other apply rejex in the helm section.Bought a bottle of Rejex and going to give it a try. Couple of questions.
1. Do you recommend to just apply it to the hull, or do you also put it on the upper sections as well (Eg. below windshield)
2. Do you just put it over the decals?
3. Any recommendations or tricks on how get the areas that on on the trailer bunks?
I only did what I can reach sitting down, did not go under the boat but some member here does that. I just hose the bottom real good.Noob question on this. The boat is on the trailer while you’re doing this right? So are you crawling all underneath the get the parts of the hull, at least that aren’t contacting the bunks?
I'm going to crawl under. Used to do the same for my jet ski.Noob question on this. The boat is on the trailer while you’re doing this right? So are you crawling all underneath the get the parts of the hull, at least that aren’t contacting the bunks?
