Remove Bench Seat
I_squared_r
Medellín, Colombia
Anybody figure out a way to quickly remove the bench seat? I need more room for the girls to dance. Im trying to make the small boat work. Single guy problems :winkingthumbsup"
I took mine out and put a 90qt igloo cooler with a seat pad on top and use it as a bench or take it out to fish.
keep it, and slide this under. it's literally perfect:
Great for cooler storage, not so much for hot chick dancing space :D :D
I drove my 190 around for awhile with a "less than attached" bench. I simply had the bolts loose on the inside. With those loose, you could put the seat off pretty easy, including when you sat on the edge.
I would think we could work something up to make it a "quick disconnect" type of system to allow your lady friends room to shake it up.
