Replacement Rear main pole for Bimini top
toddgray519
I have a 2023 222z and broke my rear support pole for the Bimini top has anyone found a reasonable replacement for it. I contacted the Yamaha dealer it lists for $276 and is on back order
has anyone tried a replacement that might fit via Amazon
craigabarr
which pole are you talking about? I lost one of my support poles for my Bimini for my 222X and I was able to find all of the parts needed and make even better poles then the factory ones. Look nicer and stronger. If it's the same, I can show you all of the parts I had to buy. It was less than $100 for everything.
toddgray519
The main support pole that runs along the entire rear of the canvass
MrBubbaGump
I had a local place here fabricate a whole bimni for just slightly more than that.... I'd see if a local place can make you a new leg or possibly two better ones.
toddgray519
Thanks I will check what type or name should I look under aluminum fabrication shop ?
MrBubbaGump
Bimini / T-top / Canvas shop or sunbrella local dealer
zipper
Boston Whaler
What model again?? I can find them for the S's and X's here. Item #7 or 8? Or do you mean #4. 2023 Yamaha 222 S (HXT1800EY) Bimini Top / Carpet | Yamaha Sports Plaza
It would be cheaper to buy the fittings and a piece of 7/8" s.s. or aluminum if you want oem and make your own, if just a straight piece. You can get on-line or a local West Marine. Straight tubing supports are easy, even using s.s.
I made these (2) s.s. 1" Bimini supports w/ fittings for around $90.
toddgray519
Sorry just seeing this yes I’m looking to replace the item # 4 in the photo they are still on back order any suggestions
