    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
Replacing e reverse module
Ralph195
North Miami Florida
195 G
Hi fellow jet boaters.
Does anyone have pics or videos on removing the e reverse module (INR)?
I have a Scarab 2016 195
Everything looks straight forwards on the plate, what I'm scratching my head on is on the removal of the cable on the module.
Thank you
Thank you blthlt
Yes that is the module.
I figured it out....there is a plate that acts as a retainage where the cable turns from silver to cooper.
You have to open this plate that is like on a hinge and it allows you to pull the cable up and out of the big plate.
You also have to remove the part at the end the one that has the cutler pin by unscrewing it of the cable, and lastly you have to pull off towards the end of the cable the black bushing to be able to pull the cable off thru the hole in the big plate.
It took me a couple of hours analyzing the module to figure it out.....LOL
Thanks for your interest to help me.
