I had a friend bring me a set of Anodes back from the states as getting them here in Thailand is just about impossible, I had noticed there was some confusion on where to locate the Anodes on the side of the Engine block so i thought i would try to make it a bit clearer with a few Photos also just to help thing's along, It's a fairly easy job if you lay on top of each Airfilter and bring your right arm around the back of the engine to help support the socket wrench, Mine came out very easy after undoing the 12 mil securing bolt with a small socket i found i could just twist the anode body out of the cylinder block easily.
Engine Anode and part number you need 2
Anode housing seal you need 2
Anode for the side of the jet Pump you need 2
To locate this Anode it's on the left side of the Engine block as you open the Engine cover just behind and underneath the last fuel injector, If you lay on top of the Airfilter you will see it clearly a small 12 mil socket is all you need
This is what you will see, Undo the larger 12 mil bolt as the smaller one actually holds the Anode in place in the housing.
Ok this is both Anodes out, I was really surprised as i have never changed them and this is after 10 years in saltwater, It just goes to show what a good flushing does.
I just give them a clean and also cleaned the seals and applied some silicon and put them back.
All refitted and back in place, It took about 5 minutes on each Engine so a simple job that you can tackle yourself.
Jet pump Anodes and part number you need 2
You can see how much the saltwater has attacked these Jetpump Anodes compared with the new ones, Not bad though for 10 years use in Saltwater
All finished and ready to go, I used a longer bolt in the Jet pump Anodes as the one that comes standard i feel isn't long enough and only goes in about 4 threads and steel to Alloy and only 4 threads is just asking for trouble as it's so easy to over tighten anyway good luck i hope this helps you to locate the Engine Anodes better.
