Sidarousmg
- Mechanicsville, VA
- SeaDoo
- Challenger
so yesterday was one of those murphy's law days....while cruising the lake we sucked something up and ended up with zero thrust. had to get a tow back to the marina. i did not pinch the exhaust cooling line (couldn't find the right one in time) but towed at less than 5mph. while at the marina, I pulled the nozzle and saw that a hat (ball cap) was wrapped around the impeller. I pulled out the pump and managed to get it cleaned up, doesn't look like any damage to impeller or wear sleeve. put everything back together and put boat in water for a test, but engine wouldn't start. it would turn over once then just stops. this morning while going through everything I did yesterday, i realized that i'm getting a "sensor" message when i first install the DESS, followed by 4 beeps 10 seconds later, so i'm thinking the neutral safety switch is out. i pulled up the lever and removed the switch, it clicks fine if I use my finger to press it, but engine still wont start. I'm tempted to bypass the switch all together, at least to confirm that this is the issue. but before i start cutting wires, i wanted some more experienced opinions from the Seadoo Gurus on this forum. my questions: 1. do the symptoms i described sound like the neutral safety switch is the issue? 2. could yesterday's events have in some way led to the failure of the switch (maybe while moving the bucket up/down by hand while removing the pump) 3. in order to bypass the switch, do i just cut the 2 wires leading to the switch and connect them together? I really appreciate all you help in advance, this has really ruined an otherwise beautiful weekend.
