RGB led speaker lights for 222xd
xxICEMANxx84
212SD
For those of you who just got a 222x model boat. All of the speakers are fitted with RGB led lights. I just purchased a spool of rgb wire from Amazon and a led controller from crutchfield by wet sounds. I'll be wiring everything up this weekend. I just took delivery of the boat yesterday. I'll attach pictures of the finished product.20230406_152051.jpg
just got my 222XD. What can you do with the RGB led lights?
I got a spool of rgb wire on Amazon and a Bluetooth RGB controller and wired up my speakers
Sorry for the late update. I forgot that I had posted this ?. My bad. I'll try and get more pictures if I remember.
What / how did you wire the power to? I’ve seen approaches to Navigation or Courtesy Lights… I have a 2023 AR220 and installing Kicker 45KM654L for context
I connected my kicker controller to the courtesy lights. Works fine with 8 speakers. The RGB doesn’t pull much at all. Since I used combo speaker and RGB wire I put a fuse box in where I can tie in additional RGBs when I get around to it
I wired my to the auxiliary switch so that I can turn on the lights without having to power on the boat
I'm also getting LED speakers and possibly additional RGB lighting, I'd like to be able to turn the LEDs on an off with the courtesy lights. My understanding is that I should use a separate controller for the LEDs and somehow connect it to the courtesy light circuit. What does this connection look like and what type of controller?
For those of you who just got a 222x model boat. All of the speakers are fitted with RGB led lights. I just purchased a spool of rgb wire from Amazon and a led controller from crutchfield by wet sounds. I'll be wiring everything up this weekend. I just took delivery of the boat yesterday. I'll attach pictures of the finished product.View attachment 197974
Hi was it difficult to fish the wiring through for the RGB speaker lights for all the speakers I just got a 222xd and confirmed by removing a speaker that the wet sound speakers have the capability to be wired for RGB lighting
its not bad. recommend you have a steel fish which makes it easier. WEAR long sleeves, the fiberglass is nasty and bites.
If you have a 222x it already has RGB speakers all you have to do is wire them. After that you need to connect them to an RGB controller. EPBOWPT RGB/RGBW LED Strip Light Bluetooth Controller. Google it this is the one I got. And attach that power to what ever power source you want. I can't speak on your boat because I don't know what you have
Exactly. I used an old metal hangar with some tape on the end of it. Gloves and long sleeves is a must though. I wired mine to one of the spair auxiliary switches and they work great.
When you say you wired it to the spare aux switch (or courtesy switch) what did you wire to that, the +12v power side? Or is there an on/off function on the controller that you connect to the switch and have the power wired to the house switch?
I wired the 12v pos to the aux from the Bluetooth controller and that is my on/off because I wanted to be able to run those lights without having to have the ignition switch on.
So the speakers already have the lights in them and just need wires ran to a power source??? How about the tower speakers?
I wanted to connect mine to the helm or courtesy lights, but I’m not sure which wires are either. Can you help me out?
Let me see if I have a pic. I used the hot on the switch on the dash.
Sor
sorry I was thinking of my other boat. On the Yamaha I used the remote wire from the HU to the amps as my hot. Ground to the ground bar.
On the other boat I used the hot from the courtesy lights - back side of the switch. Or option 3, you could add a simple toggle switch and power the switch from your positive bar and ground to the negative. Just be sure to add a fuse in line.
Hello, just an update I just saw this thread and started the project myself. I unscrewed all the speakers to find the 4 pin connector not connected. Ive basically created my own wiring harness for the 4 pin connector connecting most of the to a Y and running it to the next set. I am waiting on the RGB controller so not to sure how thats going to work. I also taped into the the accessory button on the bottom left and tapped into the negative on the usb port on the top dash. I will post some more photos when I can but here a few
