Ridesteady Install- 2019 AR195
Wake_Dude
AR195
Hello everyone. Finally took the plunge and ponied up for a Ridesteady. Here is a quick write up on my installation. I couldn't be happier with the quality of the kit, the manual, and the service from Ridesteady. Going to test it out next week on the lake!
I decided to do some steps out of order (sue me, LOL) and started with installing the main display. See that shitty phone holder? That is going to be the sacrificial lamb for the display. Wasn't really a fan of it to begin with. It is very simple to remove, two bolts and nuts (which are easily accessed behind the helm).
Once the phone holder was removed, I made a horizontal line between the two holes and then marked center on the line and drilled a pilot hole. The phone holder's location is perfectly centered on the dash and is a great place to mount this display. Sorry for the angled pic, it makes the line look off, but it's straight. LOL
Wake_Dude
AR195
Next was to drill the hole. I used a circle cutter from HF (see link) that worked perfectly for this application. It works best in a drill press, but can be used with a hand drill, especially in soft materials, i.e. plastic/fiberglass.
If you want a perfectly concentric and accurate hole, buy a set of calipers to measure out your cutters correctly. I measured the diameter of the ridesteady display and adjusted my cutter to OD + .005 for a perfect fit.
Hole is drilled very clean.
Wake_Dude
AR195
Next was to slide in the display and mount behind the helm.
The bottom of the backing plate had to be trimmed a bit to clear the fiberglass behind the plastic panel, then secured with the provided hardware.
Wake_Dude
AR195
When deciding where to mount the GPS sensor, I didn't like the idea of having exposed wire anywhere, and I didn't want to mount it inside the helm, so I modeled up a quick pod for the sensor to sit in and then 3D printed it.
Wake_Dude
AR195
I decided to mount the GPS assembly behind the steering wheel, which is oriented for a direct view of the sky through the center of the windshield. The assembly was secured using velcro.
Wake_Dude
AR195
Now for the boring wiring madness, lol.
Tapping into the ignition. Taps covered with electrical tape.
Green wire to Nav light gray/blue
The manual does an excellent job of stating how to hook up all the connections within the engine bay so I'm not going into detail with that, but here are some pics for reference.
I will say that I was not able to get the APS connector off without temporarily removing the APS. The latch was against the wall that the APS was mounted to and I couldn't get a finger in there to detach the connector.
Oh, and wrap all of your wiring in the protective plastic sheathing.
Wake_Dude
AR195
I decided to mount the CPU using heavy duty velcro. It is very strong; I've used it to mount much heavier things (i.e. amps) and have had no issues with it. The CPU feels like it weighs 0.5-1 lb. Clean the fiberglass prior to mounting.
CPU mounted and tidying up the wiring.
Wake_Dude
AR195
That's a wrap! If y'all have any questions, let me know. I'll be testing the ridesteady 6/19-6/28 and will be sure to report back. I'm sure it's going to work great.
See ya on the water!
QuakeTen
AR195
Looks great. Thanks for sharing. I am thinking about putting one on my ’19 AR195 but may have to wait until winter as my boat is already in the water and docked. How long would you estimate an install would take for an average guy?
Wake_Dude
AR195
Thanks! For me, it took a full day, but I'm slow, LOL. I try to be very meticulous and keep everything tidy and do a clean install. I've heard of others installing in 3-4 hrs. YMMV. Not a great amount of skill level is needed. The manual is very clear and straight forward. The most critical part of the install is drilling that hole in the dash for display. Take your time, measure correctly, and use the appropriate tools; it should be no problem. If you have any questions, please don't hesitate to ask. I'm glad to help out.
Georgetown, IN
Great install and write up. Love the detailed pictures. Very well done.
Ridesteady has been on my wanted mod list for awhile, just keeps getting moved back on the list for other things.
I'll be on the lookout for your on the water review. Everyone seems to love it, but for various reasons.
Wake_Dude
AR195
Thanks, I appreciate it!
Definitely can't wait to try it out. These boats bleed a ridiculous amount of speed for a given throttle setting when turning, which is a nightmare for the rider. I got tired of the speed variations when wakeboarding. My lady and other drivers had/have a hard time compensating with the throttle; there's just too many variables to get it right. Very optimistic this Ridesteady will cure that problem. I'll definitely report back!
Wake_Dude
AR195
I also installed Ridesteady this weekend. 2017 AR195. Can't wait to get it in the water to test it out.
Lookin' good! Be sure to report back any pros/cons/tips after you test! We can compare notes, lol.
gallobg
MasterCraft
Wake_Dude - you beat me to posting this! I just installed a RideSteady in my 2019 AR195 about 2 weeks ago in the exact same spot. Until now I hadn't found any pictures of anyone else who installed the same way. Although I used a Dremel to cut the circular hole for the control unit - your cutting tool looks much nicer to use.
For me the install took about 4-5 hours since I went very slow and steady. Cutting the circular hole in the dash was the hardest part since I really, really didn't want to screw that up. The rest of the install was very straight forward and the instructions are top notch.
I mounted my GPS under the windshield and above the instrument cluster. I found there was a gap between the parts that the wire would fit through. Although - I very much like your 3D printed holder! Would you mind sending me the STL file in a private message? I'd love to print that out for myself.
For the past few weeks we've been using it and loving it. Not having to mess with the throttles all the time has been so great, especially when making turns. These boats bleed off a lot of speed in the turns when towing a tube, but that's not a problem anymore! It makes driving the boat a lot nicer since its one less thing on my mind.
gsbrown
Hilltown, PA
AR195
For mounting the GPS receiver I went with this location because on my boat there is a gap for the wire to fit into. Want to make sure catching a signal isn't a problem before permanent install. IMG_5988.JPG
Wake_Dude
AR195
Thanks for the feedback! Your dash/display looks great!
Regarding the STL file; no problem! I'll send it over in a PM. It was printed on a Creality Ender 3 pro which reads metric rendered meshes. If your printer reads in inches, let me know and I can convert it for you in CAD and send it over STL with inch format.
Glad to hear you've been enjoying the Ridesteady. Man I can't wait to try this thing out. Only a few more days!
