Riva intake upgrade
dancathy
Fort Dodge, IA
Has anyone put the riva intake upgrade on a 2015 242 ls. If so what is the model number. I screwed up and bought a couple using part number someone gave me off the other site. They are for non supercharged but I just got them yesterday an went to install this morning but they are to big.
Williamsone46
Lehi, UT
255XD
Link in bio MWV-RIMUK-FZ-11
PolarXJ
Kennewick, WA
@Williamsone46 Do they make much of a difference? Are they just a drop in mod or do they need any additional items?
Williamsone46
Lehi, UT
255XD
They add a little throttle response, and increase the rpm by about 200 giving you a few mph.
Speedling
Cedar Lake, IN
SS
Should help with elevation as well if you have an issue of the rpm's being low in higher elevations.
PolarXJ
Kennewick, WA
Great thanks guys. Is it a simple drop in mod? Are their any other parts required for it?
Ronnie
SF Bay Area
Will this fit on older (2010) 240s?
Speedling
Cedar Lake, IN
SS
Should fit on any of the 1.8's I believe as their intakes are all the same from my understanding. I don't have one, so couldn't tell ya.
I thought there was a quick write up on here somewhere. It had to do with the elevation thing is why they bought it. @Williamsone46 was that u?
Williamsone46
Lehi, UT
255XD
@PolarXJ simple install. @sysinu did a video of the install.
@Ronnie 2010 - 2012 part # MWV-RIMUK-VX-11 and 2013 - 2015 # MWV-RIMUK-FZ-11
sysinu
Park City, UT
PolarXJ
Kennewick, WA
Thanks for posting the video!
Does this part void the warranty? I wouldn't really think it would since it is on Yamaha's accessory website.
MikeyL
Passed Away
In Memoriam-RIP
Lake Oconee, GA (Greensboro)
@PolarXJ ....... Yes. But talk with your dealer ........ since he is responsible for handling the warranty claim, he is the 1 in the best position to answer.
Bruce
Royal, AR
Just to be clear, this is removing the backfire arrestor?
I understand the legal concerns but are there practical safety concerns?
Speedling
Cedar Lake, IN
SS
Not so much on modern fuel injected engines that compensate for proper air/fuel ratios.
sysinu
Park City, UT
Yes, this removes your flame arrestor and if someone were going to make a big deal about finding your flame arrestor (which is required for legal reasons) you would need to provide the flame arrestor at the air filter.
I highly doubt a water cop is going to make you rip apart your engine air intake system to prove you have a flame arrestor unless there is some nature of an obvious problem.
Ronnie
SF Bay Area
Some guys have gone through more rigorous inspections than I but sisinyu is correct in that you are removing the flame arrestor and replacIng it with a pass through cylinder to smooth the air flow in that joint but if you use an aftermarket airfilter like that of r&d or riva it is the new flame arrestor, so you are once again covered.
OrangeTJ
El Dorado Hills, CA
Hmm...If you remove the restriction of the flame arrestor at/close to the throttle body but then add back the restriction of a flame arrestor at the air filter, have you really created a system with better ability to flow air?
Ronnie
SF Bay Area
I think it comes down to comparing the stock and aftermarket airfilters. The aftermarkets seem more open too me but I'm just eyeballing it. The aftermarket sleeve is definitely more open than the stock ribbon. The best breathing system is probably the one with the sleeve and without any airfilter at all but that's not the configuration I plan to use on my boat.
