Noko
- Lake Nokomis Wis
Can I ask what these cost and where you purchased them ?Stock initially but then I replaced them with the R&D antibackfire ones. I used those mainly because they are nonrestrictive and they fit into the stock air filter waterproof boxes.
I would have to see some documented and reliable testing to believe 3 MPH increase all else being equal. Water/wind/load would be a bigger factor.
My opinion on this is that if you boat at or near sea level removing the stock ribbon and / or installing the throttle body spacers (the r&d versions are called manifold upgrades I think) will not improve top speed or rpms because the engines are already running to their limits as defined and controlled by the ecus. That is these engines are governed / rev limited.
That stated you may be able to reprogram your ecus to improve performance but doing so is not inexpensive. Alternatively if you want to improve acceleration or top speed regardless of the altitude you boat at go with custom pitched impellers but realize that theoretically you cannot improve acceleration without reducing top speed and vice versa.
