swatski
- North Caldwell, NJ
Unless I have this all wrong, and PLEASE let me know if i do, and Im basing this on Williansone46 pics, the ribbons are made into or attached to the throttle body insert? (item 17 on the exploded view). If you can just take out the ribbon, youre golden and know it for a fact. If you have to remove the insert itself to get the ribbons out (they are attached in a way that you cant remove them without removing the entire insert) you have to put something in that void so your airflow laminar matches the throttle body, otherwise the lip the insert is riding on will ruin anything you gained by removing the insert.
And Im not endorsing Riva. (BUT when i raced jetskis they are damn good!) I even state that if you have to remove the insert, here is how to make one ;D
Also, when air/liquid flow are talked about, often what the pencil says you see in the real world. Not trying to argue you, but honestly, you do have it backwards. What you DO often see is the misapplication or not taking the system as a whole into account so the science gets discredited when in actuality what you changed (streamlined) did work but the bottle neck was elsewhere.
Let me give you an example. Exhaust. The exhaust on our boats, or any mass manufactured engine, is so restrictive, optimizing it can give you HUGE benefits to both power and fuel consumption. But federal regs, based on cars, say that certain things have to happen in exhaust systems for a clean burn.
Okay, just quickly, the ribbon is fitted inside the throttle body/intake manifold with a rubber ring/seal. (BTW - that thing (the rubber seal) should not be left behind - if it gets sucked inside the engine - causes a lot of damage - someone posted on that here or the other site with pictures, don't remember now). Plenty of pictures of ribbon delete. I do not know of anyone reporting performance benefits of replacing that rubber seal with the riva ring. I understand the theory.
Basically, the air flow appears to be limited by the ribbon, but does not seem to be further limited by the turbulence resulting form the absence of a ring or a seal (which would serve to smooth out the air passage) - it just does not seem to matter if you have the ring in there or not.
I believe that your statements about the potential benefits of opening up the exhaust are not well founded. Strait through exhaust systems have been tried in jet skis and boats and generally discounted for having small effect on performance/power increase and large effect on increasing the noise. If I remember correctly @Speedling has experimented with that, maybe he can chime in.
