rocker switch light out
eticket
Hi all,
I got out for the first time this season yesterday and the light on my bilge rocker switch is not working. The bilge pump still cycles on every few minutes, I verified that back at my slip were it is quiet. All other rocker lights work and other systems function (radio, horn, nav/courtesy lights/blower). I am thinking the switch went bad, but like to get any inputs if these can be repaired. I would think that light is a built in LED, so not repairable.
I thought maybe a loose wire but if I remember from installing these type of switches in my Jeep, the power for the system being switched is powering the light, so that does not sound likely given the pump still has power. Maybe these switches have independent power supplied for the light, 2015 212X by the way.
Thanks for any inputs!
