Rotax 4-Tec Supercharged Oil Type - Need Help
hvluve
Glastron
GT
Guys, I'm thinking about changing the oil in my 2015 Glastron 187 model, and I'm wondering if I can use any other types of oil or do I have to use OEM XPS oil?
BobJohnson
Highland Park, il
Chaparral
VR
@hvluve here's a couple threads which have some oil info:
https://jetboaters.net/threads/rotax-engine-substitute-oil-filter.12918/
https://jetboaters.net/threads/engine-oil-for-supercharged-intercooled-rotax-engine.20737/
there might be more related info in the Scarab and Chaparral sections. Suggest going into each section (rotax, scarab, chaparral) and searching 'oil' within them.
from all the posts I've read, the oil below is perfect for our engines at 1/2 the brp oil cost. I've always used the brp oil in my boat, but this spring, strongly considering switching over to the Rotella
Dean P
Florida
Chaparral
VRX
That's what I use too. Just do a search for the oil pictured above. There's lots of info on this.
hvluve
Glastron
GT
Thanks for the inputs, the only thing is this oil is labeled for diesel engines & that's why I wasn't sure if I should go with this or OEM.
Dean P
Florida
Chaparral
VRX
You'll be fine. There's tons of good info here on this oil. Search...
John P Jones
HO Impulse
Is there somewhere I can order the coil packs for Rotax 4-Tec 200's?
Plug misfiring and the marina wanted $100/coil pack. I found some second hand replacements on line for MUCH less, and it worked fine, but it started popping up - not staying down as tight as the OEM PN. So I'd like to find a direct replacement without spending $100/coil pack. Having 2 powerplants in the boat, that can get expensive.
BobJohnson
Highland Park, il
Chaparral
VR
Probably better if you start a new post on this. Might get more views. I found the coil here but it’s $108 each. At least this gives you a part number to work with for searching. Try searching seadoo sites too. Might help. 0460679 Ignition Coil - Johnson/Evinrude, OMC | Crowley Marine
hvluve
Glastron
GT
Did you switch over to Rotella? If so, how's it perform for you?
BobJohnson
Highland Park, il
Chaparral
VR
sorry for late reply.... yes, been using Rotella for last 2 seasons and it is perfect. I'm on a vortex Facebook group where others use it as well and all positive feedback.
MD23679
KUWAIT
255 Open ID
I use AMSOIL , never had issues . Make Sure its NOT 100% SYNTHETIC .
The codes are as follows: SM: Vehicles manufactured between 2002-2009.
FC-W stands for Four-Stroke Cycle, Water Cooled Gasoline Engine Lubricant. NMMA certification indicates an oil has been tested by a certified laboratory and NMMA has issued a license for that oil's formulation and it registers the approved brands that have been tested.
