Rotax
dr.marty
I have a 2018 Scarab with twin Rotax 150's they run about 600 rpm's apart, the dealer has computer synced them twice and nothing has changed. The dealer said they can't find anything wrong. Has anyone had this issue?
Dean P
Saint Petersburg, Fl
Chaparral
VRX
Is it even all thru from idle to WOT? I assume the sync button is highlighted?
Mine is off about 400 at idle but then balances out when on plane.
dr.marty
Sync light is on. Under 2k rpm and at full throttle around 7k rpm the engine show to be running at the same rpm's
JetTech72
SeaDoo
Challenger
My guess would be the PPS, sensors located in the helm, need to be tweaked to make their output closer.
That's probably where your issue is coming from.
Dean P
Chaparral
VRX
Would you be able to take a picture of this sensor?
dr.marty
Thanks for responding, I'm not sure what PPS sensor is. What does PPS stand for?
Dean P
Chaparral
VRX
I believe @JetTech72 is referring to TPS (Throttle Position Sensor). PPS stands for Pedal Position Sensor.
However, I'm not sure how to adjust/tweak the sensor. If I think of it, when I go home tonight, I'll look and see what's there.
JetTech72
SeaDoo
Challenger
@Dean P I was really referring to the PPS, since each engine operate on his own PPS a slight variation between both would create a difference in engine RPM along the loadline. AT WOT they would be both at 100%. There is not adjustment that can be done with the TPS as the system is fly by wire, thus the TPS is controlled via the ECU.
Dean P
Chaparral
VRX
Thanks for the update! Just curious what does PPS stand for?
JetTech72
SeaDoo
Challenger
@Dean P you had it correct my friend. PPS is the Pedal Position Sensor (The throttle controller for boat or acceleration pedal in a car) . It's the potentiometer telling the ECU "I want to go". The TPS (Throttle position sensor) is the throttle body opening which is driven by the ECU in a "fly by wire" operation. No more direct mechanical link between the pedal & throttle body.
In this case I think the signal from each potentiometer (PPS) are slightly out of synch.
dr.marty
Thank you all for your response to my Scarab boat issue. This forum is great. Now should I just replace both PPS or just one and would a dealer have to reprogram/relearn, or flash the ECU after replacement of the PPS? The dealer that works on my boat has not been very helpful.
JetTech72
SeaDoo
Challenger
There is no reprogramming to be done. The thing is that both PPS need to have there output lining up. Either you replace 1 or both trying to find a good match. or you tweak the bracket or play with the PPS installation. It's easier to do it when BUDS diagnostic tool is connected as you can see the PPS output of both at the same time & tweak the bracket accordingly.
dr.marty
Thanks JetTech72 for all your help I am going to replace both and will let everyone know the out come
Dean P
Chaparral
VRX
Do you have part numbers? May help other with same issues.
dr.marty
I don't have the part number if you can supply me with the PPS number would be great. I wish you were in Tennessee so I could just hire you to install them. Thanks again
JetTech72
SeaDoo
Challenger
epc.brp.com
JPS : 460304 & 460305
BRP : 277001726 & 277001727
dr.marty
JetTech72 you are amazing I thank you for helping me out with my rotax throttle issue. Just wondering why the first two part numbers 460304 & 460305? I can't match them to anything parts related.
Dean P
Chaparral
VRX
FYI... @dr.marty To call a person out you need to add the "@" first so they will be notified or you can click the reply button to notify them.
JetTech72
SeaDoo
Challenger
The 46xxxx # are the Rotax powerpack numbers while the 277xxxxxx # is the BRP Sea-Doo number.
But they are exactly the same parts.
