Anders
- SR
My SR230 2003 255 hours MR1 port engine dont get full rpm, ECU?
Cylinder #2 spark plug gets ”black”, and have been fluctuating before, now it is more steady bad. The oil level is a bit high, in both engines, so I dont think that is the problem. The oil looks good, only pure oil and no smell of gas. I have own it since 2005.
I have:
1) changed all the spark plugs, no change
2) removed airfilter (some oilsplash on it), no change
3) checked compression on all cylinder and they are good (12,5, 12,0, 12,0, 12,5 kg/cm3)
4) analyzed and cleaned all injectors, less then 2% diffrence before and after, switched place, no change
5) live tested injectors on the rail not bolted to the engine (as @Beachbummer suggest in this thread https://jetboaters.net/threads/mr1-ecu-or-injector-or-something-else.27700/) and the spray looks good, (see pics, couldnt upload movies due to wrong file extension and have only iPhone)
6) short test up on land and the rpm is okay
7) checked the impeller housing and no visibel diffrence between the two (see pictures)
If the live test looks good, can it still be ECU problem? I havent yet switched between starboard and port engines and not sure how to do it, but perhaps it is self-explanatory when open up the box?
Or could it be bad oil ventilation that @WREKS writing in thread Bad ECU | JetBoaters.net - The World's Largest Jet Boat Forum!
Happy for any advice that can solve the problem!
I have:
