  • JetBoaters.Net 2nd Annual SeaDoo Switch Group Buy Sponsored By JetBoatPilot Is Live Now. Save 25% Off Select SeaDoo Switch Gear through October 31st.
    Click Here to go to the Jetboatpilot Seadoo Group buy
    You can delete this notice with the "X" in the upper right>>>
RPM Inconsistencies
YinzerVRX
Pittsburgh
Chaparral
VRX
Hi All,
I'm new to boating and jet boats in general. I currently own a 2016 203 VRX with twin 150's. I've taken it out on the water 3 times since I bought it and noticed the top end RPM seems to vary. The first day out she was turning around 7200 and same with the second outing. I had her out today and she only topped out at 6900-7000. I used the same Pump BP 89 octane fuel each time I gassed up. The manual says it should be maxing out at 7550 but never seen that. Any reason to why I'm seeing low RPM's?
Assuming that you bought the boat used, One simple thing to change out would be the spark plugs. It's common for guys to use fogging oil during long periods of storage. So it could be possible that the plugs are fouled.
Anyway, hope you figure it out. Welcome to the site and congrats on the boat!!!
I have the 223VRX with twin 200's and RPM seems to max out around 7200. At about 40 hours I have yet to see anything above 7200. It does have a limiter that limits RPM to 6800 or so until 10 hours are logged.
Thanks for the reply's. Yes I bought the boat used with 13 hrs on it. I'll have to look at the spark plugs to see what they look like. Where I live gas stations typical change to the " winter blend" October 1st. I'm thinking this could have an effect too.
