Yes, I will send pics once I head back down to marina later this week. The Volvo Penta tabs is what I used and they work beautifully!! I can now trim the boat and drop the bow in chop.....this should be a factory option!! I was going to sell the boat because could not stand not being able to trim/drop bow in chop when I stumbled upon these tabs. I will send picks but they fit perfectly on the 215 or 255....not sure about 195 . I have a 215 HOI twin with 250 horse and made the boat dramatically better. The pad is installed on dash right under the keys so you can trim while keeping hand near throttle. Total cost was around 1100.00 and could add the automatic trim feature for another 500-600 from what JA remember. Here is the info:
Volvo-Penta QL Boat Trim System
VOLVO-PENTA QL BOAT TRIM SYSTEM
Our customers report excellent results! Scroll down to see some pictures and comments.
The interceptor consists of a small retractable composite blade that is mounted on the trailing edge of the boat's transom. As the blade is lowered it generates an upward pressure on the hull, raising the stern and pushing the bow down. The system is designed for planing and semi-planing hulls with maximum speed of 50 knots.
Compared to the traditional trim tab that extends beyond the transom the interceptor has a lower profile and is less exposed to possible damage Traditional trim tabs often use exposed hydraulic actuators to position large tabs that protrude from the transom
The
Volvo-Penta Boat Trim System kits come complete with everything needed to install the system – 2 x low profile Interceptors (either 300mm or 450mm), a Control Panel with 4 push buttons and two rows of LEDs for precise trim indication, a Control Unit (wiring manifold) – this is the brains of the system and is used for 1 or 2 pairs of Interceptors, 2 x 4-pole cables for connecting the Control Unit to the Interceptors and 1 x 6-pole cable (available in 5 lengths) for connecting the Control Unit to the Control Panel.
If you have more than one helm station, a T-cable is added and an extension cable is used to power the Control Panel and the second helm station. We are happy to help you design a custom system for your boat, please call at 866-209-6132.
There are two basic kits for single installation and one helm station, as well as separate components which are available in our web store.
PLEASE NOTE: The area of the transom where the interceptors are to be mounted must be straight, flat and smooth. If you have a question whether the BTS will work on your boat, email us pictures of the transom.
The Volvo-Penta Boat Trim System was featured in
DIY Boat Owner magazine Issue 2005-4
The article includes a step by step installation on a 22 ft boat.The sea trail results were very positive and to quote the article “beyond our expectations”.
“This simple device improves boat-operating efficiency and handling safety. Boats plane earlier and more consistently and gain stability in cornering. With the proper trim angle there's also the promise of fuel savings. Enjoy the ride!”
For a reprint of this article please contact
info@great-water.com.
Sizing Guidelines:
Many factors affect the choice of the right sized interceptors, and these sizing recommendations are based on average performance. Your choice may vary based on power, engine configuration, weight distribution, type of boat and use. The largest interceptors that will comfortably fit on the transom will be the most efficient. For semi-planing hulls, it may be necessary to increase the length of the interceptor configuration.
Please call if in doubt which size is best for your boat.
Boat Length | Single Engine Installation | Twin Engine Installation |
15' – 24' | QL300 | – |
22' – 30' | QL450 | QL300 |
28' – 34' | QL450 | QL450 |
32' – 44' | QL450 + QL300 | QL450 |
42' – 50' | QL450 x 2 | QL450 x 2 |
Download the Volvo-Penta Boat Trim System Installation Manual HERE
Displaying
1 to
12 (of
12 products)
| Volvo Penta Automatic Boat Trim Option
Volvo Penta Automatic Boat Trim Option This is an amazing product. The ABT uses GPS technology to hold the trim you set while the boat is underway. ... more info
Model : QL-TS-AutoOption
Manufacturer : VOLVO-PENTA
Weight : 7 | |
