- Royal, AR
- SX
On the firearms question and as a daily carrier, you do not need a firearm in Bimini or for the trip to and from. If it makes you feel better bring a flare gun instead of tubular flares.
If you clear customs in Bimini they will send the police to your boat to collect your firearm. You will not be able to collect it when the group returns home at 06:00 on the following Saturday. So you will have to choose between leaving it behind or returning after the group.
If you are traveling further into the Bahamas and want to take a firearm then make your first stop somewhere other than Bimini to clear customs. The firearm must stay locked up on your boat. Anytime you interact with Bahamian LE they may count your ammunition. But much more importantly acquire sufficient experience to do so safely and take other friends on their own boats with similar experience that you trust with your life.
As for the lack of cleanout ports, in 2015 I would have had to continue on with clogged jets or might have been swamped when trying to pull the sea weeds out if I had not had cleanout ports. 2014 & 2016 would have been fine.
