Seacock valve obstructed
Zach Stokes
We are getting an alert on our 2018 Yamaha 242X e series saying seacock valve obstructed but there is still water coming out the two pee holes on the side of the boat. What should we do?
It might have something to do with your ballast feeds for your bags.
Pee holes are not connected to the ballast . I didn’t get to check but as the bags empty I think it sucks up the side of the bag and the system throws that code . Once this happens it’s difficult to get the water out but if you look in the classifieds you can get the pump jumper cable to energize the pump and empty the water . You would have to fill the bag back to the amount shown on the screen next time out do the operation from the factory that uses timers .
The inlet valve to your ballast is not fully open. Nothing to do with engine or pee holes
